TwinTurbo.NET: Nissan 300ZX forum - Re: New rebuild running rich
Subject Re: New rebuild running rich
Posted by txq45 on July 02, 2008 at 9:25 PM
  This message has been viewed 181 times.
In Reply To New rebuild running rich posted by zx299 on July 02, 2008 at 08:29 PM
Message New Rebuild .. !
If you're using the Zem you should be able to lower your low idle maps so it would not run rich.. Have you changed injectors also. The aka void could be off or you do have a leaking 0 ring.
The workshop is wrong if your injectors ohm out ..
